How do you deal with Confetti
Discussion in 'Web-Presses' started by ushir, Apr 18, 2013.
  1. ushir
    ushir New Member
    Nov 2010
    Durban, South Africa
    Hey guys,
    So most of the jobs we run on our web offset presses are for dot-matrix printers and so we use punches to create the holes. We are generally able to capture about 90% of the punch holes with our confetti waste extraction system but the other 10% gets stuck in the press frames and flies all over the floor. This is a real pain as it makes the entire factory floor a mess. Have any of you guys found a good way to capture 100% of it?
    Cheers!
  2. Plan EH Inc
    Plan EH Inc New Member
    Nov 2013
    Ontario, Canada
    What are you using now to extract the punches; an auger, a local vacuum, a centralized system...?
  3. Bill Borcicky
    Bill Borcicky Senior Member
    Jul 2012
    214
    U.S. Amory, Ms.
    It would be nice to install a secondary vacuum with drop trays to catch the punches which are scattered. I know of a few machines with homemade catch trays and they tapped directly into their primary waste extraction system. I would not suggest tapping into the primary line because it can create other issues. A secondary vacuum would be better.
