hps2322
- 2010
- 14
- Irvine, CA
Hello, I sure hope someone can help me. My Horizon FC-20A trimmer is sticking in the knife down position. Once it stops it triggers the Alarm light on the Motor Driver. I need to hit the Emergency Stop button until the power drains from the motor driver then use the inch button to bring it back up. It was a once in a while problem which has grown into an almost full time problem. The chain was very loose which was causing a banging noise. After tightening the chain the banging noise went away and I thought the problem as well but eventually it happened again. I'm worried it's the motor driver or the motor. Does anyone know if the motor driver or the motor will work sometimes and then stop? I'm hoping it's not either of those two so I'm hoping somebody has good news for me and possibly even a solution. Thanks in advance for any possible help.
- Hank
- Hank
