Hickeys on blacks only
Discussion in 'Web-Presses' started by r32dan, Jul 14, 2010.
  1. r32dan
    r32dan New Member
    Jul 2010
    australia
    hi there, i am having issues with hickies on blacks only (last colour in the tower). obviously firsts thoughts would be that it must be the black ink if it is not happening on the other colours! The reps ink have assured us it it not an issue with there ink. So has the paper company, under a microscope the hickeys appear to majority ink. any suggestions. cheers......
    Ps..KBA Comet, 5 yrs old....
  2. Data
    Data Senior Member
    Jun 2010
    121
    uk
    I'm sure you'll have checked for a defective roller or debris?
  3. r32dan
    r32dan New Member
    Jul 2010
    australia
    yeah checked those, no issues with either.....
  4. lildaddy50
    lildaddy50 Member
    Feb 2008
    44
    san Diego
    You're running your black down last? Never heard of it. Try switching you sequence.
    Rod (old school)
    Peri Printer likes this.
  5. Data
    Data Senior Member
    Jun 2010
    121
    uk
    Dont take it the wrong way but nomally you can see hickies by eye.
    Do you get the same result when you print black alone?
    Is it the black isnt sitting on the previously printed inks?
    Dave
  6. graphix emporium
    graphix emporium Member
    May 2010
    11
    sydney
    Hmmm, what it could it possibly be?, soft blankets?, stuffed fountain rollers bearings?, collapsed bearings on a scavenger roller/maybe set to hard?, not cleaning your fountain rollers enough, wrong fountain solution mixture?, trap floating, ink to tacky and is piling cause it's cold/viscous?, paper PH is to high?
    ........It's a wondrous world we live in with out adequate deductive direction :)
  7. Print Consultant
    Print Consultant Member
    Aug 2009
    13
    UK
    More than likely a roller in the ink train somewhere. Middle inker that no-one likes changing probably.
    Try using a heat gun on the rollers in the black unit, That should narrow it down.
  8. Peri Printer
    Peri Printer New Member
    Oct 2020
    Hertfordshire
    I would agree a roller breaking up first port of call might be worth checking the shore hardness of the inking rollers.
    If all rollers are good try a different ink and if you have spare unit use it as a duster before the blk unit.
  9. Travis Young
    Travis Young Member
    Oct 2019
    98
    Victoria Australia
    How many black units?
    Does it happen on all black units?
    Or is the problem specific to one unit/roller train?
    Had a wrap recently on that unit?
    Maybe hand wash the unit and see how much crap ends up on the rag?
    If it's over every black unit the cause will likely be different to than if the problem is specific to an individual unit.
    I'm no web expert. I spend one night a week helping print newspapers on an old Goss Community Press but the fundamentals are still the same as sheetfed.
  10. Tlang
    Tlang Member
    Feb 2020
    40
    Nc
    Also if you use a spiral ductor I've seen the grove build up with ink to the point where eventually it'll start making contact when it ducts and it strips all that old dried ink particles into the roller train and makes for a ton of hickies
