Rashid Hussain
- 2019
- 11
- Karachi-Pakistan
Hi guys
I am now facing Feeder ON problem in SM52 Compect two color machine.
In inching, Feeder is working but when Run the machine and try to start the feeder for paper run then its not working, also feedr ON push button light not glow.
No double sheet error.
Both units damping motors are running.
Delivery table is in up position.
Replaced the both units EWK board.
At 45° double sheet detector sensor value is 577.
No errors in dyn and int tests.
Primary and secondary safties on display shows no safety.
Replaced the Encoder with zero position seting.
Is any one faced the this kind of problem then please share your remedy or any suggestion.
Regards
Regards
