Good_part
- 2011
- 106
- HongKong
1 x 00.785.0473/01 MSOP PCB
3 x 220932-00 D932.00
2 x 00.785.1042/04 Modul L-MACB-SIC-B
2 x 00.785.0709/02 SICB PCB
2 x 00.785.0707/04 MACB PCB
1 x S1, S6, S7 Switches
1 x PL.6062520 Power Supply-SL20
1 x PR.574.0207NT33 Power Supply, CPL.
1 x 00.785.1044 Module L-D932M
1 x 00.785.0984 Module 96.682
1 x 00.785.1148 Module MCCM-L-P2C2
2 x 00.785.0879 L-DSC 96.683
2 x 00.785.0964 Backplane 96.684
1 x PL.088.1400 Motor (M12) with worm-drive + coupling
1 x PL.030.2100 Motor CPL.(M3)
1 x PL.6061850 Drive Motor
1 x PR. 538.6284 Stepper Motor
1 x 00.785.1029 L-LDM Module
5 x 00.785.0983/01 MODULE 96.681
1 x PL.525.2000 Valve UNIT CPL.
1 x PL.527.2000 Valve UNIT, CPL.
1 x PL.570.200 Brake, CPL.
1 x PQ.593.5326 Maintenance UNIT with two filters
2 x PL.605.9295 Geared Motor
1 x PL.125.0000 Plate Detection Sensor
2 x 00.785.0947 P-OL PCB
1 x PL.550.3000/04 Suprasetter 74/105 Termotek chiller unit cpl.
Suprasetter SCL-MCL
1 x 00.785.0946 P-AC 96.663 PCB
1 x 00.785.0752 P-P3C2 PCB
1 x PQ.500.1200 Power Supply Vega 600
2 x PQ.050.1800 Stepper Motor (M2/6/7)
2 x PQ.500.2000/01 Switch
1 x PG.602.1026 Valve CPL.
1 x PQ.602.1027 Valve CPL.
1 x PQ.335.2000 Valve UNIT CPL.
1 x PQ.897.0000 Receiver
More Suprasetter & SCL/MCL parts on request
PR.537.3050 VACUUM PUMP
PL.570.2000 Drum brake 24V DFK458-110N
PL.030.2100 Drum Motor SER3112/4L4DS0C0
00.785.0983/01 L-LMC 96.681
Suprasetter 00.782.0740/03 00.779.1215/ Flat module ACFB
Suprasetter 00.779.1215/03 Flat module ACFB
Suprasetter 00.782.1314/01 00.779.2004/01 MUCB-AS-BP
Suprasetter 00.779.1351/ Flat module GIPB
Suprasetter 00.779.1147 00.781.8734 MCCB-L-P2C2
Suprasetter 00.779.1400/ Module ACLM-HS-LMD
Suprasetter 00.779.2018/06 Flat module GIEB-PCI-E
Suprasetter MV.050.803 /01 On-line transport device
Suprasetter MV.051.304 /04 Punch module
Suprasetter MV.053.172 / Filter cpl
Suprasetter MV.054.632 / Plate stop
Suprasetter MV.055.023 / Laser 2540 dpi 100 mW
Suprasetter MV.059.116 /02 Sensor cpl.
Suprasetter MV.101.685 / Feeler
Suprasetter PL.010.0800/ Pressing roller cpl.
Suprasetter PL.010.1800/ Sensor cpl.
Suprasetter PL.030.2100/ Motor cpl.
Suprasetter PL.070.3600/01 Temperature sensor
Suprasetter PL.082.4600/ Motor
Suprasetter PL.106.2005/01 GASKET
Suprasetter PL.115.0035/ Spindle
Suprasetter PL.115.0045/ Coupling
Suprasetter PL.489.7846/ Filter element
Suprasetter PL.500.0007/ Filter
Suprasetter PL.517.0501/ Filtering mat
Suprasetter PL.523.2000/ PUSH BUTTON
Suprasetter PL.525.2000/01 Valve unit cpl.
Suprasetter PL.525.2010/ Valve 5/2 Wege
Suprasetter PL.525.2020/ Valve 5/3 Wege
Suprasetter PL.531.0002/ Filter
Suprasetter PL.550.2001/ Filter cartridge 14208
Suprasetter PL.550.2003/ Filter TermotekNr10941
Suprasetter PL.550.2004/ Flowmeter TermotekNr13053
Suprasetter PL.550.2005/01 Control console TermotekNr15619
Suprasetter PL.551.3000/ Temperature control unit
Suprasetter PL.552.3000/01 Temperature control unit 850W
Suprasetter PL.570.3000/04 Controller
Suprasetter PL.570.4000/01 Controller
Suprasetter PL.605.2835/ Toothed belt 10T2,5/305
Suprasetter PL.605.7217/ Sucker 9.50X20.034.1
Suprasetter PL.606.0544/ Locking lever 205-UB
Suprasetter PL.606.1867/ Sensing head OPT ENCD REL
Suprasetter PL.606.2520/ Power supply SL20.101
Suprasetter PL.779.0000/02 Temperature sensor
Suprasetter PL.801.0000/02 Adapter cable cpl.
Suprasetter PL.846.0000/01 Adapter cable cpl.
Suprasetter PL.852.0000/01 Adapter cable cpl.
Suprasetter PL.862.0000/ Adapter cable cpl.
Suprasetter PL.863.0000/ Adapter cable cpl.
Suprasetter EL small MV.053.171 / Filter cpl
Suprasetter EL small MV.053.311 /01 Laser
Suprasetter EL small MV.055.656 /03 Motor cpl.
Suprasetter EL small MV.055.661 / Ring scale
Suprasetter EL small PJ.021.103 /02 Filtering mat Rueckwand
Suprasetter EL small PJ.115.001 / Filtering mat
Suprasetter EL small PJ.147.0012/02 Adapter cable cpl. X12-X36...X39
Suprasetter EL small PJ.147.0032/01 Adapter cable cpl. X12A-X42...X45
Suprasetter EL small PJ.147.0088/ Adapter cable cpl. X88-S3
Suprasetter EL small PJ.147.0204/03 Adapter cable cpl. X204-X270...,X223...
Suprasetter EL small PJ.187.040 /01 Pump
Suprasetter EL small PJ.187.044 / Fan
Suprasetter EL small PJ.187.082 / Filtering mat
EL small PJ.187.215F/01 Flowmeter Ersatzteil
LS 220932-00-01B DSP2.00 RS.02
00.785.0888/02 96.680
00.785.0984/06 96.684
00.785.0879/04 L-DSC96.683
00.785.0918/01 96.682
00.785.1147/01 MCCB-L-P2C2
00.785.0707/02 MACB (+00.785.0709/ SICB)=00.785.1042 L-MACBSICB
00.785.0707/04 MACB
00.785.0709/02 SICB
00.785.1042/04 Modul L-MACB-SIC-B(00.785.0707/04+00.785.0709)
PL.570.4000/01 TLC532F
PL.030.2100 SER31122/4L4DS0CO
C9420-9212K MOTOR VEXTA
00.785.1042 L-MACBSICB(00.785.0709 SICB+00.785.0707/02 MACB)
00.779.0879 L-DSC
00.779.1147 MCCB-L-P2C2(00.779.1148 MCCM-L-P2C2)
PL.030.2100
PU.527.2000/01
00.785.0707/04 MACB
00.785.0709/02 SICB
CTP laser module
C9420-9212K CTP motor VEXTA
00.779.0879 L-DSC
00.779.0984 96.684 back plane
PL.030.2100 motor
7.751.5697557.02 97.757-01 Head RB1 PT-R4000/R8000 Platesetters
7.757.05697638/01 97.757-01 Head MB
7.758.05697646 97.758-01 Head DRV2 Board
7.760.05697662.03 97.760.02 ADC1 Interface board
7.763.5697697.01 RCP2 P86400795-01
7.765.5700876.01. 97.765.01 PT-R8000 P10-PTR
97.801-01 97.801-01 PT-86000 P10-86 OM-2
7.799.5867207.02 97.799.01 CON-SAL U1150091 SAL8000 Autoloader
7.796.5866235.01 97.796-01 CON-MAL
9996.6160003 00.781.8912/03 B1-10
6.271.5278554.06 9996.2710002 B1-10 HDMAG
6.125.4896904.05
9.324.4337840.03
HEAD DRV1 P86400021-01
9.324.4337840.05 9-05-1700
6.608.5719275.01 00.781.8588/01
6.125.4896904.05
97.751-01 740559B.CCGP0116 7853 04/20 045157
contact: vivi.ho@sumi-tec.net
whatsapp:+86-18902841927
Suprasetter SCL-MCL
00.785.0707/04 MACB
00.785.0709/02 SICB
00.779.0879 L-DSC
PL.030.2100
PU.527.2000/01
00.785.0707/04 MACB
00.785.0709/02 SICB
CTP laser module
00.779.0879 L-DSC
PL.030.2100 motor
6.125.4896904.05
9.324.4337840.03
6.125.4896904.05
