Heidelberg Suprasetter A52 - Error 5701
Discussion in 'Platemaking' started by printer55, May 29, 2024.
  1. printer55
    printer55 Member
    Jul 2020
    80
    USA
    Hello guys,
    We have the error 5701 on our Suprasetter A52.
    We checked and cleaned the belt and mesured the tension - all seem fine.
    The log file says that this is not the edge sensor.
    Any ideas?
  2. CHOCK
    3,051
    Hi Sir:
    Please do the follow steps:
    1) Perform a visual inspection : look for loose and broken wires, improperly seated connectors, loose or
    broken wires
    Dust + dirt + tear +wear
    Edge connectors are a common source of problems. Power down the system and remove the PC
    boards. Examine the edge connectors
    for contamination and clean with pencil eraser+ contacts cleaner contacts. Reseat any loose components such as
    socket the ICs) . Reseat the boards and power up.
    3) Power supply checks:
    Check the power supply for missing voltages and voltages out of spec. A digital multimieter DMM can
    be necessary, as
    voltage specifications are quite tight: logic supplies for example: must be within + 0.7% percent of
    5Vdc up or down . All the
  3. ashok kumar
    ashok kumar Senior Member
    Nov 2017
    245
    india
    Hi
    Pls send me 3 days log file. On mail Or what's app
