Heidelberg StitchMaster ST 350
Discussion in 'Book Binding' started by Brendon McCastle, Nov 27, 2023.
  1. Brendon McCastle
    Brendon McCastle Member
    Dec 2022
    7
    Michigan USA
    Hello,
    I have a Heide ST 350 that is posting an "[E099] PLC drive 3 (Tucker)" error and will not start. Anyone play with these?
    Thanks,
    Brendon
  2. CHOCK
    3,051
    Hi sir
    Please check this;
    The Stitching head delivery monitor light sensor (IP64) did not detect a gap between sheets.
  3. Brendon McCastle
    Dec 2022
    7
    Michigan USA
    Hi Chock,
    Thank you for your reply. This error occurred after a long weekend where the main power was turned off. When we turned the power back on the machine would not even initialize. I did check the sensor and it is operating normally. I am going to call phone support today and will let you know if they can help me resolve this issue.
    Thanks,
    Brendon
  4. CHOCK
    3,051
    OK, will be a Good Idea, call for Support.
    However you must test the regulated power supply in Tolerance for the Sensor, in that way the sensor NOT can be faulty, but will NOT, for the lack of Correctly Regulated power supply in tolerance.
  5. Brendon McCastle
    Dec 2022
    7
    Michigan USA
    Turns out it appears to be a bad drive. We swapped identical drives and got errors with the faulty drive. I will leave a post once we have the drive installed and the machine working again.
  6. Brendon McCastle
    Dec 2022
    7
    Michigan USA
    Yes indeed, it was a defective drive. Bought a recon unit and it started right up once we set the card addresses.
