Heidelberg SSK Cards are not showing on cptronic display
2018
22
pakistan
Hello everyone.
I have a Heidelberg Machine Sr no.534715 it is 92 Model Machine. The issue is that there is not any SSK dyn test or init test shown on the display. i tried every thing but all in vein. i check SSK cards its in good condition. And second thing that when we select presetting menu to enter size of paper and every thing it shows warning sign.so i cant able to adjust paper thickness and size.my biggest concern is that in dyn and init test SSK cards not displaying anymore. is this is the fault in SAK board or something else. Please guidance needed.
Hi sir
Please check power supply of ntk card on the same rack .
For test use another ntk to be sure .
Attention: use the same board there is two type ntk 5 and ntk 24
Good luck
  • Hi sir:
    Please test the ribbon or flat cable, for loose or broken.
    Additional, Reset the CPU in the mother board, and clean all Edge connector Boards for, dust, corroded, and do it , with eraser pencil, and and use contact cleaner spray,
    Hello Junaid, some more info might help, are there red LEDs on the SSK boards? What is their status?
    Dear waqas these SSk boards have no LED,s on it ..i already change the power supply card but noting happens..power supply board green LED lit well.also did reset to main cpu board but all in vein ..
  • Hi sir:
    and finally REHEATING, the board, for ; DRY +COLDER SOLDER JOINTS !
    the led lit on the ntk is not sufficient please measure the 24 vdc voltage and make sure it is within tolerance, then check the voltages on the GRM cards also if they are within tolerance, and as chock said you can check the connection ribbon and the connector pins also clean them with electronic card product and reinsert the ssk cards properly
