Heidelberg SpeedMaster 52 Screen Freezing on Presseting
Discussion in 'Heidelberg Printing Presses' started by JonathanGC, Oct 30, 2023.
  1. JonathanGC
    JonathanGC Member
    Oct 2023
    10
    Ecuador
    Good afternoon.
    I work with a SpeedMaster 52 2000 5 colors with CPC. I want to realize on the press conversion from perfecting to straight printing. On CPC, the press is in perfecting but mechanically the press is in straight printing. The press has an error on Printing Unit showed at the photo. I tried to modify the size adjustment but the screen freezes (photo included) and the system doesn't work anymore.
    Please could anyone help me?
  2. Adil
    Adil Senior Member
    Nov 2021
    1,245
    Casablanca
    If the machine is now mechanically on straight mode , just reset zsk board and swotch on the machine again
  3. JonathanGC
    JonathanGC Member
    Oct 2023
    10
    Ecuador
    Hi Sir.
    Thanks for you answer. The press doesn't have CPTronic compact, it has CPTronic modular so it doesn't have ZSK board. Could you help me please with another idea?
  4. Adil
    Adil Senior Member
    Nov 2021
    1,245
    Casablanca
    Hi sir , if it s cptronic modular so you need to reset sak board.
    Be welcome
  5. JonathanGC
    JonathanGC Member
    Oct 2023
    10
    Ecuador
    Dear Sir. I reset SAK and now when I push Pre-Setting the display on CPTronic shows the error on clamping mechanisms (photo attached). I'm checking valves and pressure but if you have any solution I would be grateful
  6. Beguin
    Beguin Senior Member
    Jan 2020
    380
    Côté d'ivoire
    hello dear sir, I would like to know how the problem started? And please is this a new installation or was the machine working?
  7. Adil
    Adil Senior Member
    Nov 2021
    1,245
    Casablanca
    Are you sure that the machine is on the straight mode ??
  8. JonathanGC
    JonathanGC Member
    Oct 2023
    10
    Ecuador
    Hi dear Sir. It's a new installation and the machine wasn't working. The initial problem was the conversion from perfecting to straight mode. Mechanically the machine was in straight mode but on CPTronic Modular was in perfecting mode. CPTronic didn't let me to change to straight mode because when I pushed Pre-Setting the screen on CPTronic froze.
    Later, I reset SAK and checked the door sensor between Unit 2 and 3, then CPTronic showed me the clamping mechanisms error. I checked valves and pressure, and now I could fix the error and the machine is working. Thanks for all your answers
  9. Beguin
    Jan 2020
    380
    Côté d'ivoire
    Ok good job
  10. Adil
    Adil Senior Member
    Nov 2021
    1,245
    Casablanca
    Good luck
