Heidelberg speed master 52 4 encoder
rudysbp
I hv problem with my machine
Heidelberg speed master 52 4 2004 cp 104 S.E
The position of the machine when I want d inching
Click on the first button to sound the alarm after the second push button alarm sounding only the sound of the brake while the engine does not turn
The init-test shown
S-BLT CON 3fde
And the dyn-test shown
S-BLT CON 3fdf
Anyone can help
  • Hi sir:
    1) Init :the problem is connection cable for encoder stopped rotor position
    2) Dyn : position encoder faulty Rotor.
    Check very well, Good luck
    Blessing.
    The problem is encoder in main motor
    I have bought a new one
    But the encoder in this type need put the serial number to the encoder
    Any one can help the menu in cpc 104 for input the serial nimber of encoder
    Heidelberg speedmastee 52 4 2004 cp 104
    Hi you must have the operator manual for cpc 104 for inputs.
    and then introduce the s/n of encoder.
    Normally IDS, not need to enter s/n?
    However if need look for the operator m, and go to service display, and then proceed with the steps easy.
    Blessing
    Proceed as i did indicate
    according with his operator m and go to the service display
    Blessing
  • I have the same machine and same issue
    Could you please help me
    The encoder that was installed on the machine is SRS50-HZA0-S02 but it's damaged. We buy a new encoder SRS50-HZA0-S21 but the machine doesn't respond to the encoder
