Heidelberg SM74
Rabin
2025
15
Kathmandu, Nepal
Problem in powdering device. I removed all old powders, cleaned with air in each pipe but still shows "problem in powdering device" but seems to be working, only rarely I see it not working.
What should I do?
  • Most probably there is not enough air pressure. Press "TEST" and read the pressure on the monometer. If it doesnt stay on GREEN Zone, there could be air leak from a damged hose or the vanes inside the compressor.
    Most probably there is not enough air pressure. Press "TEST" and read the pressure on the monometer. If it doesnt stay on GREEN Zone, there could be air leak from a damged hose or the vanes inside the compre1ssor.
    Yeah it's not in green. And after inspection I found out pipe was chewed by rat.
    Thank you so much
