Heidelberg Sm74
Discussion in 'Heidelberg Printing Presses' started by Alistair Tinsley, Aug 23, 2023.
  1. Alistair Tinsley
    Alistair Tinsley Senior Member
    Apr 2023
    112
    N Ireland
    Could someone please give me some advice on what might be my problem with an inking unit.
    One unit is printing like in Photo 1 and the the other like on Photo 2.
    I have tried more ink,less ink ,more damping ,less damping etc but can make no difference.
    Would it be roller pressure?
    Have check roller to plate on all rollers and they look fine.
    I am colour washing a complete white sheet.
    Any help ,pointers appreciated
  2. Raf77
    Raf77 Senior Member
    Aug 2023
    258
    United Kingdom
    Looks more like an impression issue. Check packing/underblankets etc. Are the cylinders bearers clean?
  3. Beguin
    Beguin Senior Member
    Jan 2020
    395
    Côté d'ivoire
    Good evening dear sir I would like to know how the problem happened
  4. Jack liston
    Jack liston Senior Member
    Sep 2019
    326
    Connecticut
    Use your packing gauge to ensure you are evenly packed under blankets
  5. Alistair Tinsley
    Apr 2023
    112
    N Ireland
    Have replaced the sheet to make sure.
    Can you not just turn on more pressure from the side adjuster?
  6. Alistair Tinsley
    Apr 2023
    112
    N Ireland
    The problem came into it gradually as we went through a 20000 sheet run.Started about halfway through.I have improved it by changing the amount of ink to the amount of damping but still not perfect.Also checked packing sheet etc and replaced just to be sure.
    Thanks for your reply
  7. Beguin
    Jan 2020
    395
    Côté d'ivoire
    hello dear sir, before the problem remembers, did you change the blanket and under blanket? do the rollers touch the plate well? are the print pressure motors working normally? do the pressure jacks play their roles properly? does the ink taker manage to properly transmit the ink to the rollers? please check this item!
  8. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,095
    Vermont
    You say that one unit is printing "different" than the other, but based on what I see in the second picture it looks to me like you're printing a screen tint of multiple colors. If you are in fact printing a screen tint, then I would suggest that you're dealing with a trapping issue.
  9. Adil
    Adil Senior Member
    Nov 2021
    1,319
    Casablanca
    It's a general ink transmission problem.
    check the printing pressure between the impression cylinder and the blanket cylinder, the covering of the blanket cylinder
  10. Raf77
    Raf77 Senior Member
    Aug 2023
    258
    United Kingdom
    Did you resolve the issue?
