sir we try for whiteout damping solid print. so its. clear. no. any. strip. we. check the beral pressure it's to. good. other any. suggestion
plz, give. me. thank u for valuable time. we wait for more.
Make sure all ink forms are not oscillating,if they are moving side to side put shims on you should not be able to wiggle back and forth, you have to go one step at a time ,process of elimination
Then you need to concentrate on the ink rollers make sure they are in good shape , correct stripes, no bouncing,or moving side to side _you can also try localize problem by backing off one form at a time and running some sheets
Dear sir
Thank you very much problem is solved. Installed new form roller, as per instruction and solved this prob
Thank you very very much for your support sir.
