Heidelberg SM102 90 error
Hi Sir:
Normally, you must make a maintenance to the main motor, because, each main motor, for Heidelberg, is regulatory, that
check the main, motor, for LUBE, and general maintenanc, including brake, and Encoder.
Of course, the main contactor, must be clean, and tight, all cables(wires) .
Thank you , sincerely.
superchock@yandex.com
  • Do you have this error dirrectly on power on? Just whe you try to run the machine? Does the machine run for a while? Sometimes the cooler of the mai drive cabinet it is full of dust and the drive immediately sense overtemperature and stops. Check if the back cooler of the drive is clean.
  • this is more info about this error
    Hi Sir:
    Already check cable connector
    All good
