Heidelberg SM-74-4-L 2009 year DryStar 2000 CAN problem.
Raimis
2023
28
Latvia
When I am switching on the dryer, the lamps are starting pre heating and about 5-10 minutes are happening the pre heating, it is very long time and then after the 5-10 minutes the pre heating is switching off. And the heater simbol on the monitor is disapering too. Only fault what machine is giving is that conection between the dryer and machine is ended and (do you fixed the problem). I have the pictures too.
You need to make sure the coolant is at correct psi there are 2 tanks in main cabinet with gauges.both must be same psi .the coolant must be correct ratio water/coolant consult manual.
  • It's quite tricky. Once you've got the problem, have a look on the SPS behind the door of Dryer electric cabinet. There are some LEDs, take short video and share it with us.
    Good luck
    Hi mate,
    It doesn't look coolant pressure. There comes an error message related to low pressure or insufficient air. I assume SPS stops working, but not sure.
    Thanks for reply. I think there is not coolant problem too. See the picture. I will take a video in the electric box.
    Here are some of pictures in the dryer electric box when this fault is happened.
    Sugestions?
    Hello. Here are some videos about dryer electric box when accurs this problem and lamps are shutting down and not showing anything anymore in the monitor only saying that the conection between the machine and dryer are disconected.
    https://youtube.com/shorts/miOTz6sEfJE?si=We0iN0eJHx-hY3Pc
    https://youtube.com/shorts/xOgYQt-acBk?si=6A3oe1YYYZxaR_CS
    https://youtube.com/shorts/hqr1WysZOFA?si=_eM1b1L-dy0NOXJh
    https://youtube.com/shorts/uck9W-dn3CY?si=_spKL-Jk8YQcK7tz
    https://youtube.com/shorts/D4rwvcD41PY?si=MQU7OpEZXrfRkcxj
    https://youtube.com/shorts/cdz_O2iRV64?si=cfe4PittQ5XmNob0
    Sugestions would be great, thanks.
  • Can0 serial is damaged. Take it to an electrician and ask him to open it and look for internal damages. Once fixed. It will work again
