heidelberg sm 74 2 colour 2005
Discussion in 'Heidelberg Printing Presses' started by Alistair Tinsley, Dec 1, 2023.
  1. Alistair Tinsley
    Alistair Tinsley Senior Member
    Apr 2023
    141
    N Ireland
    Recently new with this machine.
    First time with offset printer.
    Having problem with it marking front edge of sheet as shown in he photo if you look closely.
    As far as I can see it is damping related.
    Starts the run okay with normal damping settings but after a 2/3 thousand sheets it starts to appear.I then turn up damping which gets rid of it for another cpl thousand but the problem comes back.It gets to the stage there is to much water going unto it to run the job.
    Have checked roller settings etc and all look fine to me.
    Would appreciate if anyone could point me in a direction please
    Thank you
  2. Jack liston
    Jack liston Senior Member
    Sep 2019
    338
    Connecticut
    Are your water tank temperature correct.check super blue nets are ln good condition.make sure 1st form rollers are not bouncing
  3. Raf77
    Raf77 Senior Member
    Aug 2023
    258
    United Kingdom
    Doesn't look like scumming. Is your blanket tight enough? Correct packaging etc?
  4. asem alsafady
    asem alsafady Senior Member
    Mar 2016
    189
    Amman Jordan
    Dear Ali,
    Is it at the lead edge or the tail of the sheet?
  5. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,105
    Vermont
    Assuming that all your roller settings are ok I would suggest that instead of increasing the damp speed that you try cleaning the plate with either some AGE rubbed deeply in a circular motion, or some other form of plate cleaner. Upon cleaning you will want to immediately roll up the plate and resume printing. If the issue disappears for another 2 to 3 thousand sheets without having to increase the damp speed then I would be looking at platemaking. Either the exposures or how the imaged plate is processed!!!
  6. Alistair Tinsley
    Apr 2023
    141
    N Ireland
  7. Alistair Tinsley
    Apr 2023
    141
    N Ireland
    but why would it be just the leading edge if a plate making problem
  8. Alistair Tinsley
    Apr 2023
    141
    N Ireland
    It is just the leading edge
  9. Alistair Tinsley
    Apr 2023
    141
    N Ireland
    The form rollers are good and not bouncing.
    The superblue is fine.
    Not sure about fount temperature though.
    I am going to renew fount and clean before next shift.
  10. Alistair Tinsley
    Apr 2023
    141
    N Ireland
  11. Alistair Tinsley
    Apr 2023
    141
    N Ireland
    Checked packing which is fine.
    Tighten blanket ,even changed blanket but still it continues.
  12. asem alsafady
    Mar 2016
    189
    Amman Jordan
    Did you face the problem in both units?
    If yes, check out your dampening fridge, clean, mix up new water with the desire IPA and fountain solution. (I assume that the quality of IPA and fountain solution is good).
    If NO you have to double check the adjustments of your rollers.
    Readjust your dampening from roller at the minimum contact with plate, no more than 4mm.
    All the best,,,
  13. Raf77
    Raf77 Senior Member
    Aug 2023
    258
    United Kingdom
    Is it happening on any stock you run?
    Is that strip all the time on the same place or it's moving?
    Is it ok after cleaning the blanket and then start to appear after couple of thousand?
    Vario on or off?
  14. Jack liston
    Sep 2019
    338
    Connecticut
    Allistar. Make sure your ink forms are not oscillating.moving back and forth.
  15. turbotom1052
    Oct 2008
    1,105
    Vermont
    For the same reason that streaking and roller marks happen on a press. The plate processor applies its various chemicals via a series of rollers and side to side scrubbing action.
    asem alsafady likes this.
  16. Alistair Tinsley
    Apr 2023
    141
    N Ireland
  17. Alistair Tinsley
    Apr 2023
    141
    N Ireland
    But it is a ctp machine using laser
  18. Alistair Tinsley
    Apr 2023
    141
    N Ireland
    Vario on.
    It happens just on leading edge on any stock.
    happens just after cleaning the blanket ,even changed blanket to a new one.Still does it
  19. Alistair Tinsley
    Apr 2023
    141
    N Ireland
    Have done this and still does it
  20. Raf77
    Raf77 Senior Member
    Aug 2023
    258
    United Kingdom
    I presume that you've tried with vario off and there is no difference (?)
    I'd try to set ink form rollers to 2mm damper to 3 mm and give it a try
