Heidelberg SM 72 Blanket washer Water Fault
Paul Jordan
2024
10
Uk
Hi,
I’m looking for help because I can’t clear the water level fault on the blanket wash system. its flashing which mean low water but the water level is fine. It may be a sensor fault if someone could locate me to the correct sensor or area.
Thanks in advance
Heidelberg Speedmaster 72FP
PJ.
  • It's threaded into the resevoir, you should see a hex shape on body of sensor. This 72 Speedmaster may have a metal sensor body, later they were all plastic. Just mark where the wires were, and reattach new one.
    Check junction box (where wires from sensors terminate) to make sure you don't just have a loose or broken wire.
  • Brittle from age and exposure. I’ve used a large easy-out/extractor.
