Heidelberg sm 52 2p 1998 yers
Discussion in 'Heidelberg Printing Presses' started by Bokiprint, Apr 14, 2022.
  1. Bokiprint
    Bokiprint New Member
    Apr 2022
    Serbia
    Hello friends, thanks for the reception in the group,
    I have a problem that my machine works normally at the seller; when we transferred it to me she didn't want anything but she eliminated these errors in the pictures. The technician set the perfecting position in the picture, but still can't move .
    Please help me. Thank you from the bottom of my heart
  2. Adil
    Adil Senior Member
    Nov 2021
    949
    Casablanca
    The grouping drums and the turning drum are not synchronized, in your case the machine is mechanically double-sided but in its memory it is still double-sided, you must put the machine in double-sided and try again , if it works, it's fine, otherwise you need to do a thorough diagnosis to correct the problem
    Whatsapp +212700552467
  3. Bokiprint
    Apr 2022
    Serbia
    Thank you, Adil, for the help the machine is set up in this position now I'm sending the picture but it won't be able to put the machine back on the image and the coat of arms so we're rebooting because it won't start
  4. Adil
    Adil Senior Member
    Nov 2021
    949
    Casablanca
    Now if your machine is mechanically recto-recto as you have indicated to us in the image and also on the cpc the machine and recto-recto you must reset the sak card
  5. CHOCK
    2,947
    Proceed like this:
    1) The claw returns to its initial position while a changeover or sheet-length change is in progress. Abort the command.
    – Repeat the changeover or sheet-length change.
    – Check the pneumatic valve/pneumatic connections.
    – Check the electrical connections to the pneumatic valve.
    2) The clamping mechanisms are open. Abort the command.
    – Change over to straight printing again.
    – Mechanical parts are probably defective.
    3) The claw is probably defective. Change over to straight printing again. The press is
    again ready to run in straight printing mode.
    – If the claw is not defective, repeat the changeover or sheet-length change.
  6. Adil
    Adil Senior Member
    Nov 2021
    949
    Casablanca
    Surely it is a connection problem, check the electronic card plugs the turning motor plugs clean if the plugs are dirty.
    Then reset the synchronization of the machine
