heidelberg sm 102 FP+L-1+4 perfection 1989
Discussion in 'Heidelberg Printing Presses' started by SURAJ, Apr 26, 2016.
  1. SURAJ
    SURAJ New Member
    Apr 2016
    mumbai
    we have registration issues. we run 400gsm cardboard(600micron) 5 colours straight no perfection used. when we see the sheets after delivery there is a marking of pads of impression cylinder after the 1st unit. this machine is 1+4 perfecting. that is sheets bend(damaged by pad downwards) on the pad area.we think that the cardboard is slipping backward during travelling from unit to unit. the gripper side edge is damaged on pad portion. pls advz solution. diamond pad with straight groove are fit on the machine. gripper settings are ok. pls advz solution.
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    1,035
    US, Midwest
    First, check for blown cam followers throughout machine. Diamond pad with straight groove? What is that. You either have crosscut (diamond) pads or parallel grooved pads..on impression and first transfer cylinders. Parallel groove on double drum and third transfer.
  3. exheidmech
    exheidmech Senior Member
    May 2009
    674
    USA
    How do you know the gripper settings are ok? Please describe your gripper checking procedure. I can almost guarantee you that it has something to do with the grippers and pads, most likely pefector grippers.
  4. aqazi81
    aqazi81 Senior Member
    Oct 2009
    827
    KARACHI PAKISTAN
    It looks a gripper timing issue and also as exheidmech said check your perfector.
