Heidelberg sm 102-8-p 2006
Majdi
2025
13
Palestine
Dear brothers, when i start my machine i found this problem . I need to restart the machine up to 6 times then the machine work.
Any one can help me?
Please check the attachments
Good Day Majdi,
Did all of these errors suddenly appear at once?
When you restart the machine several times to get it working, do these errors go away or are the errors still there?
Regards
Shawn
  • Yes the errors happened suddenly before 1 month..
    And when i restart the machine several times the errors go away
    If all these errors showed up suddenly together, it is most likely that you have a communication problem between the press and the CP2000 console. Have you checked all cables, plugs and pc boards in the CP200 cabinet? Try to unplug and reseat all plugs and ribbon cables inside the cabinet first.
    In the Heidelberg SM 102 CP2000 console, ink zone opening and volume information is processed and controlled by the ESK (Input/Output Control Board) and the SAK (Memory Analog Board). The local servo motors for the ink keys connect to the FZK (Distributor Board).
    The control architecture distributes tasks as follows:
    • ESK (Input/Output Control Board): Serves as the central link, transmitting all control-relevant signals between the CP2000's processor boards (REK) and the peripheral equipment.
    • SAK (Memory Analog Board): Handles analog signal processing, interfacing between the system's memory and the digital ink commands.
    • FZK (Distributor Board): Operates physically on the press unit; this is the board the ink servo motors plug into.
    (this is some information found using AI search - it may be useful in trouble shooting your problem)
    It is impossible to get these error messages suddenly at the same time
    The main issue in your machine is the ink zones problem.
    Check the power supply cable on the back side of the MOT board under the ink zones control panel.
    Other error messages like an issue with the beta.c unit, send a photo of its display.
    Ink fountain motors block could be due to motor or drive board fault, deselect it then select it on the units which giving the error.
    Circ. Register motor error due to the motor itself or its potentiometer.
    Also you have a faulty hard disk in the IPC unit.
    To guide you correctly, provide the machine information (year, model, ...)
    You have a strong Heidelberg agent in Jordan, try to contact them.
    Hello, has the problem been solved now? We also frequently deal with this kind of issue, and this situation comes up quite often.
    hello did you solve it ?
    i have same problem ink zones key works but no indicator for thier postion motors works
  • i have problem with cpc1-04
    fza8 no led illuminat i check 5v 24 to bek its okay
    the buttons works motor moves registers no problem all okay
    only led not working
    on zid no errors shows
    i reset the motors from the screen ZID THE MOTORS gose to 0 postion and it knows thats in 0 so there is feedback from tsk i think no problem between tsk and bek
