Heidelberg QMDI 46-4
SCprint
2009
toronto, canada
Technical Data
Formats
Max. sheet size 460 x 340 mm (18.11 x 13.39 in)
Min. sheet size 140 x 89 mm (5.51 x 3.50 in)
Max. print format 450 x 330 mm (17.72 x 12.99 in)
Gripper margin 10 mm (0.39 in)
Stock thickness 0.05 to 0.45 mm (0.002 – 0.016 in)
Register accuracy 0.02 mm (0.00079 in)
Direct Imaging
Imaging resolutions 1,270 dpi / 200 lpi(alternative: 2,540 dpi)
Imaging time < 4 min. at 1,270 dpi
Laser diodes perprinting unit 16
Printing plates
Printing plate for thermal imaging on supply reel, polyester base material
No. masters per reel ≥ 36 Ex. *
Blanket cylinders
Length x width 555 x 337 mm (21.85 x 13.27 in)
Blanket thickness 1.95 mm (0.077 in)
Blanket cylinder undercut 2.3 mm (0.091 in)
Inking unit
No. rollers 12 (incl. fountain roller)
Form rollers 3
Diameter of the form rollers 54.7 – 45 – 50 mm(2.15 – 1.77 – 1.97 in)
Pile heights
Feeder 900 mm (35.43 in)
Delivery 450 mm (17.72 in)
Connection power
Power consumption(at 50/60 Hz) Approx. 14.8 kW
Dryer opt. (50/60 Hz) Approx. 1.2 kW
About the press
Dimensions (length x width x height) 318 x 276 x 190 cm(125.20 x 108.66 x 74.80 in)
Weight 4,850 kg
Emission values < 80 dB (A)
Year: 1999
Excellent condition
$179,000
Please contact Mike @ 416.616.8686 or mike.smartcare@gmail.com
New Price for Heidelberg QMDI 46-4
Technical Data
Formats
Direct Imaging
Printing plates
Blanket cylinders
Inking unit
Form rollers 3
Pile heights
Connection power
About the press
Weight 4,850 kg
Year: 1999
Excellent condition
New Price! $79,999 USD
