tommy1772
- 2014
- 16
- Stoke-on-Trent
Hi folks, I'm hoping that somebody can help me, it's a bit of a long story, please stick with it!
Bought the press last year and had it delivered to my home address with the idea of printing at home and doing my digital stuff at my unit, that hasn't worked out, I never actually used the press while it was here, just spent hours cleaning it and getting lots of crusty ink off the pins bars, while oiling and greasing it all up, because it was in **** state when it arrived...
The other day I finally managed to get the press moved to my unit and I have noticed that since then the suction and blow doesn't work, it definitely did while it was here..
To get the press into my room I had to remove the control panel and while we moved the machine, the control panel dropped to the floor ripping the ribbon from the back of it, which was nice....! I think we have managed to get that back together, everything lights up where it should and all the buttons do what they should, apart from the blow/suction. We are hearing a click, which when I have taken the panel off is the relay, but there is no air or suction.. I've changed all the fuses on the pcb panel and I've pressed in the little swich that sits above the relay, because that was out rather than in like the other ones on the panel....
Anybody got any ideas? I'm not too bad at fixing things, but I am a novice, so if you can try lay mans terms that would be great!
Thanks folks, Mark
