Heidelberg QM DI - Ultramax plate - Novaless ink
coricdado
2013
82
jadranaska tiskara senj, croatia
Hello guys,
i have problem..
after only 500 sheet it accumulates a lot of ink outside of printing area.. i print on format 320x225 and below this, on blanket have big accumulation of paint.. on all 4 verk.
i use Ultramax plate and Flint group Novaless ink (watherless offset ink)..
i try to adjust rollers on ink verk and i think i was make a good job with this.. but problem is still here.
what do you think guys, what i can try?
tnx.
Hello guys,
i have problem..
tnx.
Is contaminated by cleaning method or chemicals used in the plate... Not use alcohol or disolvent (oil chemical)... Use better a organic sponge and liquid detergent for clean dishes based lemon, swap the cleaning plate making a little pressure from the one side to other (never in zigzags)...
  • coricdado hope you sorted your problem.
    How are the Ultramax working? Our diodes are close to their max... would this be an issue to adjust for these plates?
    Best R
    Never mind, don't need adjustment in diodo power.... this is a myth.
    work very well... but the most problem is in the mount and clean the plate...
    ultramax work fine for me.. but im not sure is it problem im plates? i think is not problem in plates.. for day od two, i will try Toyo ink, and i will try to clean plates on the way how augustov say..
  • Are similar to VIM technology plate form.israel, but this is no longer anymore, are dark, easy to clean, but the color is dark brown.
