BosRot
The fault is on the ink zone motors/potentiometers. The motors are turning in the correct directions according to the rotation applied by the + and – keys on the CPC control panel. When, for example, the + key is pressed the ink duct opens but the LED display shows the motion and reading in reverse(LED goes down). In addition to this the motors are also “shuffeled” around, key 1 operates motor 3, key 2 operates motor 4, key 3 operates motor 1 and key 4 operates motor 2. This is the same for each motor/potentiometer card on the machine respectively.
I have replaced the “MOT 1”, “TAS”, “ANZ”, and “MWE 1” control cards with working cards from a 4 colour machine, but no difference was made.
I have unplugged the outgoing ribbon cables to the ink ducts one by one and tested the machine after each disconnection, thinking that there is a damaged cable in the line that could be causing some sort of signal interference but have had no positive results. The power supplies have been tested and all is ok there too.
According to the nature of the problem I would think that the fault is with the card “MWE” as this card receives and processes the signals from the potentiometers and sends these signals to the display but I have had no better results in changing that PCB.
I have even gone as far as changing the display and keyboard card “ATV” with no joy.
Hopefully someone has some ideas with regards to this problem ?
