Heidelberg Hydrostar compact. Type: Basic Liner 3.L. Problem
Discussion in 'Heidelberg Printing Presses' started by Raimis, Dec 15, 2023.
  1. Raimis
    Raimis Member
    Dec 2023
    15
    Latvia
    When I am switching on the Hydrostar, it works only to water circulation. Not working display and cooler. What could cause this? Could someone help? I have the picture with the precise model of Hydrostar.
  2. CHOCK
    3,043
    Hi sir;
    Please review according with his wiring diagrams;
    1) Main transformer secondary for to feed the Display and cooler, see if there are voltage, test the fuse.
    2) look for loose wires, connectors loose, dirty, oxide, corrosion, and flat or ribbon cables, or cut cables.
    3) see his system there are battery and is a good voltage ?
    4) if everything is o.k the Switch for controlling can be defective, by normal use, or loose wires for the section respective.
