Heidelberg DI double sheet positioning button mishap
Discussion in 'DI Presses' started by Echoblueprint, Apr 29, 2016.
  1. Echoblueprint
    Echoblueprint New Member
    Apr 2016
    Hudson fl
    We have had this DI for about 6 years now and never ran across this problem.
    The double sheet positioning button will engage when pressed but it will start to feed the sheet and keep going. It will keep feeding sheets one after another without stopping. Also if you go to print anything it will start to feed the sheets and then shut down and not engage impression. The pile height light will flash as if it mis fed or skipped a sheet. Any help would be greatly appreciated
  2. Paul Cavanaugh
    Paul Cavanaugh Senior Member
    Dec 2009
    630
    Kennesaw, GA
    Are you getting any error codes when any of this happens?
  3. Echoblueprint
    Apr 2016
    Hudson fl
    No error codes just shows as a mis feed
  4. Paul Cavanaugh
    Dec 2009
    630
    Kennesaw, GA
    If I were to guess the sheet detector is bad or misaligned. But typically it throws error codes.
