Hi,Hey. In your manual everything is written how to set up.
Is there a problem????
Dear all,
Nicolas, you are right, degrees are not found in the manual.
Please let me know do you have a standard or pre set feeder?
Hi Nicolas,hi, Can anybody help me? I need to adjust the feeder timing in a CD 102 year 2012
in machine manual dont say the degrees.
Hi Asem,Dear Nicolas,
At pre-set feeder, first check the sheet arrival degree 40.3°.
If this is not the case, check as follows:
1- The automatic sheet arrival control.
2- The adjustment between suction head and the feeder.
3- The sheet slow down device must be correctly adjusted.
When you are sure the above points are correctly adjusted, you can adjust the sheet arrival.
