Heidelberg 74 Baldwin circulation parts
Alistair Tinsley
2023
155
N Ireland
Need water Speen controller block.
Pipes got broken of and blocks cracked.
Need replacement parts.
Anyone have any idea where to go to look bits
Photo attached
Thank you in advance
Hi Sir:
Here is the Contact for Baldwin . Baldwin Graphic Arts Inc. • 2096 Grand Avenue, Baldwin, NY 11510 • Phone 516-546-6695 • Fax ... 516- 223 7991
  • Thank you
    Does the water control valve do anything special or would a 4 way T cross fitting do with a tap on the outlet?
    Would that work?
    Thank you
    Hello
    Thank you for replying
    Details on photo
    Thank you
    The fountain solution supply to the press is adjusted by
    means of the supply line valve.
    There 2 condition: Valve Open: Supply fountain solution,
    b) Valve close: No fountain solution.
  • Hello
    Thank you for replying.
    I understand what you are telling me
    But if I replaced the valve block marked x with the 4 way cross and put a tap control on outlet to machine marked red arrow would the circulation work ?
