Have you problems with direct ink application? TrueTONE is the colour calculator
SMALL FORMS SYSTEMS
2008
Spain
We offer you an opportunity: Going ahead of your competitors!! The TrueTONE System is a tools set whose only purpose is helping the printer in his daily work, making easier the ink formulation as well as solving the daily problems.Efficiency and speed in the formulation of direct offset colours. Discover each of the advantages this tool offers you! !
Some of the characteristics that make that TrueTONE System® is a great investment are: sea una gran inversión son:
*It is not necessary to be a colourist,The software assists you all the time in the creation of the colour, indicating you what kind of ink and which proportions must be weighed to obtain the desired colour
*Colour repetitiveness,You can repeat a work already carried out and obtain the same colour exactly in the desired quantity so many times as you want. It doesn´t matter how much ink you need, you will always obtain the same results quickly and efficiently
*To obtain a wider range of colours,With only seven base colours, you will be able to carry out a wide range of colours that will meet your needs. The system allows several reading methods of the colour: by the spectrophotometer, XYZ coordinates, LAB, Spectral Curve...
*To obtain a sample of the real colour before the printing,With the extension machine patented by TrueTONE®, you will be able to reproduce an extension of the final colour without you need to put the work in the machine. You will be able to see the result in advance, and even to show it to the client for his approval
*To economize on stock and time,Due the color repetitiveness, we will only weigh the necessary quantity. Forget to store a high number of mixtures. You will only need the bases of the System.
Thanks to the inks mixer and the roller cleaner, you will reduce the time you wasted mixing and cleaning
*Overprinted works,
We can simulate in advance which is going to be the result of our mixture, without need to take it to overprint.
The system simulates the effect that the laminated causes on the printed colour
*Colour adjustments on different supports,The mixture is carried out depending on the different available supports. For every support, a correction which is made, allows you to equalize the result on different materials. This fact which causes a great quantity of problems to our clients, is solved in a effective, simple and easy way to be checked
*The printing machine will not be stopped,At the same time as you prepare the machine to start printing, you can have the colour ready to be used, with a consequent and important reduction of time in such usual works.
*Colour laboratory,Using TrueTONE, a proof bank will always be available for you whenever you need. You will be able to check that this bank is really easy to be used and its results are excellent
Looking dealers around the world. truetone.com
