Has anyone seen this and fixed it? Ricoh Aficio CL7200
Andy B
2022
Canada
Did you change a toner cartridge prior to this message? (Did you shake it up first?) Sometimes they go bad before use, try a new one and see if that resolves the issue (message goes away).
  • Did you change a toner cartridge prior to this message? (Did you shake it up first?) Sometimes they go bad before use, try a new one and see if that resolves the issue (message goes away).
    Yes it came up after replacing black toner.
    I have tried everything under the sun but this msg does not go away.
    The black developer isn't receiving any ink at this time as well. And this msg popped up after replacing black cartridge.
    I am quite certain that until this msg goes away, it will not feed toner to developer.
    Any help is appreciated.
