hard cover,calendar,paper ,cardboard hole perforate machine 550
cxautojohn
2013
China
Machine with paper perforate function and also include hardcover punch function,why not choose to help you do the hole perforate?
Advantage:
1. It’s wide applied for punching different paper size, max punching width 550mm and 3mm thickness of hardcover.
2. Easy operation and high safety.
3. To make special punching hole is available for the customer’s request within the size of paper.
4. High quality for punching without deckle edge and accurate punching position.
Technical data:
Max. sheet 550x600mm
Min. sheet 120x100mm
Max punching thickness 3mm
Weight of paper 60-350 gsm
Punching speed Up to 7200 punch times/hour
The max height of paper 500mm
Power 3PH 380V 50HZ(other voltage on request)
Main motor power 3 KW
Dimension(LxWxH) 2200x1300x1200 mm
Net Weight 1600 Kg
[video]https://youtu.be/CsYb5cT5rJo[/video]
https://www.facebook.com/100006506731167/videos/1884605815099625/
