Hamada B452 or B252 sheet bouncing/registration
Discussion in '4-Color Offset Presses +' started by pressman1, Dec 17, 2015.
  1. pressman1
    pressman1 Member
    Sep 2012
    24
    So.California
    Intermittently my sheets bounce, my head stops are all on zero. Is that correct?
    I always set the side lay according to sheet thickness.
    Thank you,
  2. spikeboy
    spikeboy Senior Member
    Sep 2014
    62
    new york
    Zero may not be ideal if the headstops are to low you may bounce tohigh same thing
    if you have 100# text place sheet at headstop lower until sheet can be pushed through
    then bring back up untill sheet stops then run not to familiar with hamada check wheels and feedroller if pess has
  3. spikeboy
    Sep 2014
    62
    new york
    Been on here for years as spike where have all theold guys gone.
  4. pressman1
    pressman1 Member
    Sep 2012
    24
    So.California
    Thanks! I'll try that.
  5. aqazi81
    aqazi81 Senior Member
    Oct 2009
    821
    KARACHI PAKISTAN
    Where is Richardk?
  6. mperezanda
    mperezanda New Member
    Mar 2016
    Ecuador
    Help for Hamada
    Does anyone know someone that can help me with the software and maintance of a Hamada BIRC 552. The software is nor working and obiusly the machine neither. We just don't know what to do or who can help us.
  7. Yeslek
    Yeslek Member
    Jan 2015
    19
    Nashville TN
    I have had some issues with this on the Ryobi 524's we have. Brush wheels being set properly often is the culprit. If they are too far forward on the sheet will cause a bounce. I have also seen wear on the swing arm cause this.
