Hi Sir:
Please Reset the Cpu. and test the Vcc ( regulated power supply for the Cpu)+ Clock in Mhz.
Test the battery for RAM, and clean all contacts for EPROM.!!!!
the current exciting out of nominal values means the main drive detects over current, you must verify the oil viscosity, do you have the correct oil type?, the other thing you must check is the oil inside the gear transmissions connected to the long shaft, there is a connecting hose with a manual vavle to permit oil going into the transmission gears must be open when machine rotates the oil go to the gear box and fill it until is filled then you must close the manual valvle and leave it close no closed the oil must remain inside the gearbox this could be the problem why only in the mornings you have such over current at main drive.
