Hey kam, I'm on a job at the moment so I'll just spitball a bunch of things to check. If you can narrow it down from there I may be able to provide more detailed help
1. Is the belt to the air pump on
2. Is air pump working
3. Does the air pump still have a filter on it, if so is it clean?
4. At the sensing servo do you feel air flow
5. Lines could be full of dust. Remove air lines to the sensing servo from the Hymod unit and blow them out. Do not blow air into the Hymod
6. Is the pink cab on top of the adjustment knob
7. Can you make the hydraulic cylinder move via the adjustment knob on top of the Hymod
8. Hydraulic fluid level good. Overfilling it can damage it and stop if from working. And of course to low a level isn't good either.
9. Hydraulic pump working correctly, may have to crack lines to see if it's pumping
10. Is the web aligned in the machine? I will generally when approaching a unit that isn't working correctly check the web coming off the unwind. Have seen many times were the unwind isn't set correct and the web guide can't overcome the offset.
11. Motor running and the coupling between it and the hydraulic pump good.
12. Also are all your solenoids opening like they should for auto.
13. Along with the solenoids, controls correct. Auto, Off, Center switch or buttons working.
