GTO 52 impression jackets
Discussion in 'Heidelberg Printing Presses' started by mantman, Oct 27, 2016.
  1. mantman
    mantman Senior Member
    Nov 2015
    274
    Greece
    This is a perfector machine running KCMY configuration, equipped with 3 chrome jackets and one coarse -at 3rd Unit color magenta- and i have register and impression issues.
    At units 3 and 4 -magenta/yellow- i have to put extra 0,10 pressure to achieve a good quality of print without mottling. My register issue is a bit weird at 4 corners of sheet -35x50- i get good register BUT in the middle magenta needs backwards 0,05 to 0,10.
    I used gauge to see the difference from bearer ring at jackets and noticed that units 3+4 have +0,35mm over bearer and at units 1+2 i have +0,45mm.
    My blanket+underlays are 1,95+1,15=3,10 -0,05 tension -waterless print needs extra pressure+compressible blankets-
    Today i tried one sheet of 0,05mm at plate of K -and removed from blanket- and got better register still this magenta thing troubles me. Could it be jacket issue?
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    1,035
    US, Midwest
    What do breakaway solids look like?
  3. mantman
    Nov 2015
    274
    Greece
    Will give it a go when i get new set of blankets
  4. exheidmech
    exheidmech Senior Member
    May 2009
    674
    USA
    How old is this GTO? Does it have the dial with the indicator inside for proper pressure setting or does it have the white arrow? Also, its not uncommon for GTO cylinders to get bumped out of alignment if there is a crash. Where are you getting the jackets from? Heidelberg jackets or aftermarket jackets?
  5. mantman
    Nov 2015
    274
    Greece
    @exheidmech i think it is 1993-94 model
    Pressure indicators are outside and look like man roland rekord/600
    Crashes not that i know of -hope not :)-
    Jacket change took place before i took over and the last jacket was altered for chrome instead of perfector since second previous operator used perf jacket to perforate and perforated the jacket :)
  6. exheidmech
    May 2009
    674
    USA
    Check to make sure that the distance between the blanket cylinder bearer and the impression cylinder is .35mm with unit on impression. In this position the adjustment dial should read zero.
  7. mantman
    Nov 2015
    274
    Greece
    Filler should be a tight drag or enter between bearers free? Monday will post photos of solid breakaways. Magenta at gripper and tail have more density than middle, also changed to Finito packing and have consistent pressure than manila sheets
  8. mantman
    Nov 2015
    274
    Greece
    [​IMG]
    In this photo these lines are electrical interference so dont mind them :)
    [​IMG]
    [​IMG]
    [​IMG]
    Paper was coated 115 gsm -0,11 mm thickness-
  9. junker1984
    Jan 2010
    1,035
    US, Midwest
    Regretfully, that's not a good sign. Your next step would be to indicate the runout of the cylinder surface with the jacket removed.
  10. mantman
    Nov 2015
    274
    Greece
    Meaning that cylinders took a hit or something?
  11. junker1984
    Jan 2010
    1,035
    US, Midwest
    Don't want to jump to conclusions, but that appears to be the case. If you don't care to pull the impression jacket, start by indicating the blanket cylinder. That should tell you how much farther you need to go.
  12. mantman
    Nov 2015
    274
    Greece
    I suppose you mean the entire surface of cylinder O.S to D.S and grippers to tail for any abnormalities?
  13. junker1984
    Jan 2010
    1,035
    US, Midwest
    Just one area in the center of image area will be sufficient. From the appearance of the breakaway you pictured, one run from gripper to tail should prove runout. Possibly a combination of collapsed cylinder/bent journals. But again, you'll likely prove the same thing by simply removing the blanket and checking the blanket cylinder. Hope I'm wrong!
