all alone
- 2010
- 20
- Ireland
Hi all....
I operate a Heidelberg 52 4 colour with Baldwin cooling and alcolor damping. My Z rollers are intergrated in the damping. I use 10% alcohol in the cooling system. The problem is that my Damping form roller gets excessive ink transfered onto it during the run and this happens soon after the run starts. I know what people are going to say regarding to much ink been released onto the rollers but trust me that isn't the problem. This problem gets alot worst when i am using spot colours and not process ink. The more this roller gets a build up of ink on it, the harder the transfer of ink from plate to blanket becomes and the images becomes washed out looking. The ink i am using is Hostmann-Steinberg. I also add in my damping 0.5% of a water hardening agent (Salinofix / Hostmann) and damping additive Combifix-xl (Hostmann) 4% which gives me a Ph value of 5. I have had a lab test my solution and they say it's fine. I have replaced all the ink form rollers and the damping rollers with new original Heidelberg rollers have reset them using a good heidelberg engineer. All areas of this problem have been looked at i think but hoping that this might have happened to someone out there and the solution is on hand.
Thanks all.
Thanks all.
