GTO 52-4 Envelopes. Bad pitch.
Discussion in 'Heidelberg Printing Presses' started by Andrei83, Feb 23, 2024.
  1. Andrei83
    Andrei83 Member
    May 2017
    61
    Russia
    Hello. There is a print run on the envelopes. I start the feed, 1-10 pieces are served, then the delivery of envelopes stops. If you print paper, there are no problems, the paper feed works well. Help me understand why envelopes don't go in the car. Thanks
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    1,168
    US, Midwest
    This issue may be due to the urethane being worn down on gripper fingers. Apply a strip of tape over holes on pad surface of traveling feed gripper, if press then continues to feed, you may need to replace or adjust gripper fingers.
  3. Andrei83
    Andrei83 Member
    May 2017
    61
    Russia
  4. Adil
    Adil Senior Member
    Nov 2021
    1,331
    Casablanca
    There is perhaps some feeder setting to do , thickness or air to rectify
  5. Raf77
    Raf77 Senior Member
    Aug 2023
    258
    United Kingdom
    Printing envelopes may be quite tricky for unexperienced operator. It depends on what size and type of envelope it is - self seal open envelope need to be feed differently to peel and seal ones etc .It's very important to know how to setup feeder for envelopes. If you are able to post picture of the envelope you print, I'll be able to give you more details.
  6. Leonard Cahill
    Leonard Cahill Member
    Jul 2017
    8
    Summerside
    Make sure there is good rubber on the feedboard grippers , the tension is equal both sides and the air holes line up to the holes on the gripper itself. Wallah had this many times
