GTO 52-1 1996 Not Starting or Locked
Discussion in 'Heidelberg Printing Presses' started by Shahjee, Nov 6, 2020.
  1. Shahjee
    Shahjee New Member
    Nov 2020
    Karachi
    Hi Everyone & Greetings to All..
    I Purchased a Machine Heidelberg GTO-1 52 last week , Machine is Beautiful, But I m not Able to Run it , Kindly Help me.. I Did not Know How many safety Switches are there and what are the main factors that i miss after installing it.. its 3 face.
  2. Travis Young
    Travis Young Member
    Oct 2019
    98
    Victoria Australia
    There is a little switch at the bottom of the delivery pile so the press can't overload. I've heard of them being bumped/damaged during transport. It's the one known to catch people out. Otherwise just the guards, double sheet detector and little bars between the plate and blanket cylinder. You'll hear a little click from the electrical box when you move the right one. Try the one at the bottom of the delivery first.
  3. junker1984
    junker1984 Senior Member
    Jan 2010
    1,152
    US, Midwest
    For sure, Travis. He can also be sure hand crank is fully inserted. I'm not sure if there's a U28 voltage monitor on a single color Goat, but it will prevent control voltage to enable running if voltage is too high or low.
    Travis Young likes this.
  4. Shahjee
    Shahjee New Member
    Nov 2020
    Karachi
    Thanks for your kind attention .. i check all the things.. they were performing .. but machine is not working and still locked because of its drive.. Card Issue diagnosed..
