GTO 46 Paper feed won't stop
Discussion in 'Heidelberg Printing Presses' started by Travis Young, Oct 16, 2021.
  1. Travis Young
    Travis Young Member
    Oct 2019
    98
    Victoria Australia
    Hi all,
    Posted this a couple of weeks ago and thought I had it resolved, but alas it is not so.
    My feeder suction won't switch off.
    We have replaced the limit switch under the feed board but still no different. Also disassembled the manifold on the front of the pump and cleaned out 50 years of paper dust.
    Any thoughts appreciated.
    Thanks in advance.
  2. Beguin
    Beguin Senior Member
    Jan 2020
    389
    Côté d'ivoire
    hi dear sir make sure to check the function of the part when you press the stopper. see the picture sent to you thank you very much.
  3. junker1984
    junker1984 Senior Member
    Jan 2010
    1,127
    US, Midwest
    First, check “sniff piston” above drive motor. (You don’t have holes in traveling feed gripper covered with tape, do you?). If sniff piston is operating properly, remove DS cover and check that solenoid operating on/off of vacuum is not blocking vacuum relief port when not wanting to feed sheets.
    asem alsafady likes this.
  4. M Herbert
    M Herbert New Member
    Dec 2021
    Illinois
    Silly to mention but did someone turn on the switch on front of press for manual feed without impression
    On my 52 it’s on left side of feeder
    Travis Young likes this.
  5. Travis Young
    Travis Young Member
    Oct 2019
    98
    Victoria Australia
    Unfortunately I wish it was that simple.
    Certainly not silly to mention. A failure in that switch would produce EXACTLY the same fault I'm currently dealing with.
  6. Travis Young
    Travis Young Member
    Oct 2019
    98
    Victoria Australia
    Thanks Junker.
    Sniff piston appears fine and switch it activates has been replaced.
    Is there anything I should know before attempting to remove the drive side cover?
    Knowing Heidelberg I suspect it's not 3 bolts and a tap with a hammer.............
    Lama Manu likes this.
  7. junker1984
    Jan 2010
    1,127
    US, Midwest
    Before you pull DS cover, are you seeing sniff piston plunger moving in/out while not feeding sheets? If you see it moving, is it possible the switch lever has been bent away from plunger? Have you homed out the switch to be sure it's working? While press is idling, can you manually trigger switch to stop sheets from feeding?
  8. junker1984
    Jan 2010
    1,127
    US, Midwest
    Travis, The switch lever on sniff piston would have to be stuck in "closed" position in order to continue feeding sheets...I mentioned otherwise. As to pulling off DS cover of feeder, it's pretty straightforward.
