Loupeyeyed
- 2010
- 110
- jacksonville
Could someone please convert gsm to # weight for me. I'm in Florida and cannot understand the weight. Let's just start with.000 of an inch if thats okay.
Let's start with this one. In the paper world weight and thickness do have a relationship it's true. But, a 350gm gloss board isn't the same thickness as a 350gm silk - they're both coated art but have different caliper. Try another, a hi-bulk uncoated 104gm can be as thick as a 115gm. Basically, it's the aeration of the sheet whilst being made that can account for bulk or thickness differences between similar weight stocks.Try this RichyK, weight is the same thing as thickness.
TSo technical my friend, why the abrasiveness? Do you think that you are better than a U.S. citizen? Are we all lazy and engulfed with fast food and convenient lifestyles? Not me my friend, talk all the smack you want, put me in your shop and watch the other pressman crumble with envy. You can say all you want and try to get as technical as you can. But, you don't know me and never judge someone with assumptions. I'm sure your good but that doesn't make you GOD.
So what linescreen is YOUR shop printing on uncoated, lets just start there. And by the way what is your approach to printing in synthetic stocks.
Can you balance ALL of them or are there some that just don't drink enough water.
You might be good but guaranteed, I KNOW BETTER!!!!!
First, please give Richard (and all the other forum members) some respect. I probably don't have a fraction of the experience you may - but being rude has no place here and is counterproductive.You might be good but guaranteed, I KNOW BETTER!!!!!
Try this RichyK...
This is simply not true the way I understand weight and thickness relating to stocks. Weight is not the same thing as thickness. Pick a few different type sheets of the same weight off the shelf, one gloss coated, one smooth or a digital smooth dense finish, and one uncoated/rough and compare for yourself. While the same weight, there can be a lot of difference in thickness depending on how dense the sheet is. Look at the different height of a stack of 1000 sheets of each different type stock of the same weight. So I also simply do not understand you saying that... either way, I see no reason for rudeness when everyone here should be friends as we all can learn something from each other.weight is the same thing as thickness.
Try this RichyK, weight is the same thing as thickness. Or are we weighing pallets? So technical my friend, why the abrasiveness? Do you think that you are better than a U.S. citizen? Are we all lazy and engulfed with fast food and convenient lifestyles? Not me my friend, talk all the smack you want, put me in your shop and watch the other pressman crumble with envy. You can say all you want and try to get as technical as you can. But, you don't know me and never judge someone with assumptions. I'm sure your good but that doesn't make you GOD. So what linescreen is YOUR shop printing on uncoated, lets just start there. And by the way what is your approach to printing in synthetic stocks. Can you balance ALL of them or are there some that just don't drink enough water. You might be good but guaranteed, I KNOW BETTER!!!!!
