Graphic Spray Reset Fault history
Discussion in 'Heidelberg Printing Presses' started by Keeping It Real, Feb 16, 2024.
  1. Keeping It Real
    Keeping It Real Member
    Feb 2023
    12
    England
    Hi
    I have a Graphic spray on Heidelberg SM74-5 with
    Electronics-box 3000
    The Spary has a menu "HardWare Faults"
    There are many faults showing
    I would like to know how you reset clear all faults so that when I run my spray unit only the actual fault is showing.
    The error displayed on the CP2000 screen "
  2. Adil
    Adil Senior Member
    Nov 2021
    863
    Casablanca
    your question is not very clear, qurl error message do you want to eliminate??
  3. Keeping It Real
    Feb 2023
    12
    England
    I am asking if anyone knows how to clear the fault history which is located in the spray menu under Hardware Faults menu.
    Someone who works on the spray unit will fully understand my question.
  4. Joe Burger
    Joe Burger Member
    May 2023
    14
    Germany
    The powder spray device is coming with a compressor and you should check it. Mostly, this problem occure when pressure is inefficient.
  5. Keeping It Real
    Feb 2023
    12
    England
    Hi Joe. First thank you for your reply. The motor pressure is perfect. Fully Serviced by myself. The basics are not in question here. The problem is I would like to clear the fault history. So in the future, I can check and determine new faults.
    The faults showing have no date or are placed in order. So i am unable to determine which are the latest faults, and therefore need to clear the histroy
  6. Adil
    Adil Senior Member
    Nov 2021
    863
    Casablanca
    Please enter to the diagnostic menu and gibe me the detail of fault ,
    Which machine is this if this is sheetfed control machine please try to give me error code for this fault to know ewactly what happends
  7. Raf77
    Raf77 Senior Member
    Aug 2023
    226
    United Kingdom
    OMG guys:D
    He doesn't ask to help him understand the error codes, but how to erase previous errors to see only the new errors - which will appear after clear errors history
    Is understanding the questions really that hard?:D
  8. Adil
    Adil Senior Member
    Nov 2021
    863
    Casablanca
    Where is the previous error ?? He showed me the picture of error message to erase this error you need to solve the issue that s why i told him to give me error code or more details
  9. Keeping It Real
    Feb 2023
    12
    England
    Thank you
    Yes, I am only asking how to clear the error codes
    I fully understand all the codes and how to fix
    I just wanted to know if it’s possible to clear all codes.
