Goss M600 problem
MRTYMM
2015
138
egypt
Dear all
I have problem with ssk card in folder m600
Web guide motors and turn bars ..etc
Doesn't work if I put value for turn bars don't excuse I found
Ssk in dyn test give general error f7f7 in ssk1 and ssk2
We had this happen on both of our M600s before where everything is lit up as though it is moving. Sometimes cycling the power several times will get it to clear for a little while. You can check the pots and hope that there is a bad potentiometer that is shorted causing the erratic feedback, however you most likely have a bad board/card. Like I said hopefully it's just a bad pot, but 4 out of the 5 times I have seen this happen before we had to replace a board.
  • We had this happen on both of our M600s before where everything is lit up as though it is moving. Sometimes cycling the power several times will get it to clear for a little while. You can check the pots and hope that there is a bad potentiometer that is shorted causing the erratic feedback, however you most likely have a bad board/card. Like I said hopefully it's just a bad pot, but 4 out of the 5 times I have seen this happen before we had to replace a board.
    Thanks for your reply
    We changed ssk card and it works good
    Also we have a problem with omni color
    We need new card with guarantee wp5372527-02
    Try GP Poland they seem to have the best prices on used parts. I know they stock a lot of hard to find cp tronic parts for our older 600
    Could you please send email for gppoland
    Also I have a problem with megtec splicer
    I have problems with splicer in automatic and manual splicer when I push manual splice button 9pb splicing doesn't work Also in automatic splicer 3 mtr doesn't rotate when red roll loaded
