FTA 37 Error-any help
Discussion in 'Large Format Inkjet Printers' started by Simon S, Nov 11, 2016.
  1. Simon S
    Simon S New Member
    Nov 2016
    cambridge
    Hi
    We are running a Xuli printer, it has recently been displaying :-
    FTA 37 - Epsom head error has occurred
    and results in no control of printer either through LCD screen or Printmanager software.
    Has anyone had any success in fixing this?
    So far we have,
    1. Changed head to a known good one, this head was taken from another printer when it was working, placed in the Xuli, same error, replaced to other rig, working fine.
    2. Replaced head board - no difference
    3. Replaced Flexi from head board - no difference
    4. Replaced +- 42V supply cable - no difference
    5. Sworn at it - no difference
    Have spent numerous hours on the net, everything points at the video from 3 years ago on youtube, no fixes that I have found.
    Any help gratefully received.
    Simon
  2. Vish B
    Vish B New Member
    May 2017
    South Africa
    Hi Simon. Have you fixed your printer
  3. Simon S
    Simon S New Member
    Nov 2016
    cambridge
    Yes we did thank you, it was a mix up with the flexi supplier, sent double sided flexis where the contacts where on opposite sides of the flexi at the ends, the old flexi had contacts on 1 side of the flexi only, so in effect it was reversing the flexi at the head! Doh! Anyway all sorted.
  4. Narendra
    Narendra New Member
    Nov 2017
    Bangalore
    Hi sir
    Our eco machine alpha has same problem.
    Fta 37 error printhead error occor
    Pls give soultion
  5. Jennifer Calhoun
    Jennifer Calhoun New Member
    Jan 2018
    Mississippi
    checking to see what was the fix for this error getting the same error on a new wide format printer I have
  6. Joshua Sebatane
    Joshua Sebatane New Member
    Nov 2018
    South Africa
    Kindly assist. I have a Xuli X6 3200 printer. FTA 37 EPSON the print head error occurs. I have replaced 4 core power cable, but error still persists. Can anyone assist? Any suggestions or recommendations will be highly appreciated.
  7. bekkie ndlovu
    bekkie ndlovu New Member
    Jul 2019
    zimbabwe
    hie i have a xuli x6 1880 im getting an fta 37 saying dammage of head board drive unit. this occrred after changing the head board. i dammaged the old one .please kindly assist
  8. bekkie ndlovu
    Jul 2019
    zimbabwe
    please help. somone?
  9. bjquines
    bjquines New Member
    Sep 2020
    Laguna
    Hi, I have this problem and I replace the fuse in the carriage board. It fixed the problem, but the head is not firing. So I'm looking to find more parts to replace.
  10. Shahab
    Shahab New Member
    May 2023
    India
    Please refer the video
  11. superkale
    superkale New Member
    Oct 2024
    Bulgaria
    I got an error fta 37 Damage of head board drive unit. Can someone help.
