Sorry Bro, I do not understand your press situation quite good
- Front lays Motors 1M61= DS and 1M62=OS are working well or not?
- Motor automatic sheet arrival 60M61 working well or not?
- Serial number of Press?
- I cant explain you how to do basic adjustments the front lays, if you havent done this before I recomend get somebody elso to do it. You would need some special tools to do that as well...
- To adjust the front lay motors you have to measure the paper bite in the impression cylinder gripper bar and adjust it according that, fot doing that you have to set the front lays to middle position (9mm) in the press center menu
- To check the BAR Sensors 1B213 and 1B249 you have to:
1. Set frontlays in Press Center to 8mm, be sure that all front lays are activated (to do so you must turn each of them anticlockweise until stop)
2. Insert and allign a paper sheet to frontlays, tight the rear edge of sheet with duct tape to the feeder table
3. Move the front lays in press center from 8mm in steps direction 10mm, the perfect timeing would be @9,3mm +/-0,1mm when both of LED-s on the Feeder MID Screen goes off
... Hope you see the picture, because I have no glue yet how to add pictures to my threads...
4. The distance between Sensor and Front lays must be in this position 1,3mm +/-0,1mm
5. Due the fact that you set first paper bite to 8mm + paper sheet was taped to the table and later you move it direction 10mm, the paper bite value (front lays adjustment) must show 9,3mm +/-0,1mm when LED-s goes off at Feeder MID Screen. If not so than you have to adjust it into this parameter window. You can use also a special tool to do his adjustment HD catalog Nr. is: BV.005.3230
Hope you can manage it...
