Kylin machinery
- 2020
- 26
- Hongkong
Hello everyone in the Color Printing Forum community,
If your facility is still relying on manual labor to strip waste paper after die-cutting, you already know how it can bottleneck your post-press production and delay delivery times.
I'm Jacob Liao, CEO of Kylin Machine Company. We are an industrial packaging machinery manufacturer based in Wangjiang Industry, Dongguan City, China. Today, I'd like to introduce a tool designed specifically to eliminate this bottleneck: the Kylin KY-680 Pneumatic Carton Waste Stripper.
The Core Advantage:What usually takes hours of manual, physical stripping can be completed in just 10 to 30 minutes with the KY-680. It increases stripping efficiency by up to 10 times, significantly reducing labor costs and speeding up your order turnaround.
Key Specifications & Features:
You can view the full technical specifications, watch live operation demo videos, and see it in action here:https://kylinmachines.com/machine/the-carton-stripper/
If you are looking to improve your finishing department's efficiency, or if you have questions about packaging automation in general, feel free to drop a reply in this thread or send me a direct message.
Best regards,
Jacob LiaoCEO, Kylin Machine CompanyWangjiang Industry, Dongguan City, ChinaWebsite: kylinmachines.com
- Powerful Pneumatic Motor: Equipped with a German-engineered air motor delivering 800W of power and 3000 R.P.M. for stable, continuous, and heavy-duty operation.
- Durable Diamond Gear: The stripping chain gear is specially heat-treated for high hardness and wear resistance. The gear bite is precisely designed to grab and pull away waste edges cleanly without damaging or jamming the main carton body.
- Wide Material Compatibility: Works perfectly across a variety of materials, including 150GSM–1000GSM cardboard, single/double wall corrugated board, and laminated corrugated paper.
- Ergonomic & Lightweight: The unit weighs only 4kg. When suspended with a standard spring balancer, the operator bears zero weight and only needs to guide the tool's direction. It is incredibly easy to learn, and operators can master it in minutes.
Best regards,
