FOR SALE: Kylin KY-120C Heavy Duty Tape Cutter - 24/7 Continuous Operation, Up to 120mm Width
2020
26
Hongkong
Hello everyone in the Color Printing Forum community,
If your facility processes high volumes of tape or protective films, you already know that standard desktop tape dispensers simply cannot handle the demands of a heavy-duty industrial environment. They often jam, cut inaccurately, and break down under continuous use. To solve this common bottleneck in finishing and packaging lines, I’d like to introduce the Kylin KY-120C Heavy Duty Tape Cutter.
I'm Jacob Liao, CEO of Kylin Machine Company. Based in Wangjiang Industry, Dongguan City, China, we specialize in manufacturing high-quality, reliable automation equipment for the global printing and packaging industry. We understand that the stability of every auxiliary tool on your shop floor is critical to maintaining high overall efficiency.
The Core Advantage:Unlike standard office or light-duty cutters, the KY-120C features an all-metal internal structure and heavy-duty cutting components. It is specifically designed for rigorous, 24/7 continuous industrial operation (three-shift work environments). It is built to last and effectively eliminates downtime caused by tool failure.
Key Specifications & Features:
  • Extra-Wide Capacity: Supports cutting widths from 20mm up to 120mm, and cutting lengths from 20mm to 999mm. Perfect for wide protective films, copper foil tapes, foam tapes, and double-sided tapes.
  • Dual-Roll Synchronous Cutting: The machine can hold and simultaneously cut two rolls of tape—even with different outer diameters or materials. This allows a single machine to supply a multi-material assembly station efficiently.
  • High Precision & Speed: Driven by a precision stepper motor and dual optical sensors, it ensures a feeding and cutting accuracy of ±0.5mm. It operates at a speed of up to 44 pieces per minute (based on a 100mm cut length).
  • Smart Memory Function: Equipped with an intuitive LED display that automatically saves your cutting parameters when powered off, allowing operators to immediately resume production upon powering back on.
  • Wide Material Compatibility: Whether you are cutting PVC tape, non-adhesive materials, fiberglass tape, or heavy-duty packaging tape, the bidirectional feeding system ensures smooth operation without edge curling.
This unit is compact (weighing only about 8kg) but delivers pure industrial-grade productivity. Because we are the manufacturer, we offer highly competitive factory-direct pricing and reliable technical support.
You can view the full technical specifications, photos, and capabilities of the KY-120C here:https://kylinmachines.com/machine/heavy-duty-tape-cutter/
If you are looking to increase the automation of your packaging department or rigid box assembly lines and stop wasting labor hours on manual tape cutting, please feel free to drop a reply below or send me a direct message for a quote.
Wishing you all smooth and productive operations!
Jacob LiaoCEO, Kylin Machine CompanyWangjiang Industry, Dongguan City, ChinaWebsite: kylinmachines.com
