For sale: Bobst Speria 106 E Autoplatine (2006)
Tomek Guzdziol
2020
Poland
For sale
740mm x 1060mm
year 2006
STANDARD EQUIPMENT
MACHINE
- Centerline system for quick job changeover.
- Electronic device for sheet travel control.
- Adjustable centering at stripping station.
- Control cabinet cooling unit.
- Bobst-Electronic machine operating system C.U.B.E. (Control Unit Bobst Electronic).
This microprocessor based Bobst system allows the operator to easily control, visualize and check the various functions and elements of the machine.
- Main motor with frequency converter control.
FEEDER
- Pile tray with handle allowing manual lateral correction of the pile during production.
- Synchronization device timing the sheet arrival against the front lays when the machine is at a standstill.
- Pile lifting controlled by Pressfoot.
- Rear pile guides (OS and OOS).
- Side blowers adjustable with Centerline marks.
- Suction unit.
FEED TABLE
- Covered with an anti-static stainless steel plate.
- Feed table inlet equipped with lateral ramps.
4 Front lays, adjustable in pairs with front register control.
- "Pull" guide (OS) adjustable according to Centerline marks, with side register control.
- Double sheet detector.
- Support plates at entry of platen station.
- Sheet hold-down device (guiding the sheets to the front lays).
- Upper frame with manual lifting device.
- Upper transport equipment for paper, paperboard and corrugated board.
- Transport belts.
With lateral guidance and automatic tension system.
PLATEN
- Gripper reopening device.
- Equipment centering and locking.
- Locking of the chase against the upper beam.
- Measurement of the cutting force with strain gauge.
1 Synthetic material supporting plate.
1 Upper chase : fixed bottom plate
1 Cutting plate
WASTE STRIPPING STATION
- Air-cylinder-driven lifting of the upper frame.
1 Upper pull-out frame
Including crossbars and clamps.
1 Lower pull-out frame
DELIVERY
- Pile tray.
- Front jogger.
- Adjustable rear and side joggers with Centerline marks.
- Braking brush.
- Manual non-stop rack.
AVAILABLE EXTRAS
B MACHINE
1 B-1 Elevated machine l
C Feeder
1 C-4 Manual non-stop device
E PLATEN
1 E-5 Compensating plate
1 E-55 Adjustable supporting plate centerings (micro adjustment)
F WASTE STRIPPING STATION
1 F-31 Upper pull-out frame quick-locking device
Available immediately, loading in Poland
Email: tech@2press.pl
WhatsApp/telefon: +48 790 228 233
