Film Laminator
ballykea
2008
184
Pennsylvania
Priced competitively and is a workhorse.
Centaur 52 is equipped with adjustable pneumatic pressure roller rolling system.
Chrome-plated steel main pressure roller
All film translation parts are individually adjusted by means of a pneumatic system
The separation unit is also automatic, easily adjustable to handle films of different weights.
The management of the machine is controlled by a computer that controls temperature and working speed. A sensor keeps constant the temperature of the pressure rollers that can reach a maximum of 150°C.
The nominal working speed is about 40 feet/minute and it is adjustable.
The machine is equipped with the film perforation system
Working width: 20"
Maximum length: 28" if fed automatically, infinite if fed manually.
SPECIFICATIONS
Unibody Construction.
Automatic sheet lamination and integrated separator
Totally pneumatic, in the laminating section and in the tear-off section
Cylinder pressure is adjustable by means of a pressure gauge integrated in the machine
Pressure separating rollers, driven by pneumatic pistons and a pair of anti curl rollers on delivery side Sheet collection table
The roller is heated through a 2000 W resistor
Adjustable roller temperature.
Adjustable machine speed
The sheet feed controlled by a pressure roller, automatically adjustable to allow a perfect overlap of the sheet. Maximum Film roll diameter - 20" of 28 mylar mechanically regulated by friction.
Film perforation system, which allows automatic tearing of the laminated sheet
Main control with Kw.0 60-Hz 50/60 gear motor - Single-phase electrical connection V.240 -HZ 50
Options include auto feeder, three-sided trimmer, and receding stacker.
