error code 108 on a Hamada H234
Discussion in '1-Color and 2-Color Offset Presses' started by muske99, Apr 16, 2014.
  1. muske99
    muske99 Member
    Apr 2014
    5
    Illinois USA
    Hello,
    Getting a 108 error code on a H234 - can't find reference to that number as to where issue is - has been intermittent - but tripping frequently now
    Any help appreciated
    muske99
  2. FFR428
    FFR428 Senior Member
    Feb 2008
    438
    CT
    The console should show the location of the error no?. Sometimes the side panel covers/doors can come loose and will trip a error. Little bugs drove me nuts till I figured them out. WAY too many sensors and safety gadgets on these. Can't remember what 108 is sorry. Would be 08 on the console I think if it applys. Can check monday if you don't get a answer. There was one time one of the impression light sensors was starting to go. Check to see they are all in working order. When 1 goes it relays to the next as a missed sheet and stops the press. PIA for sure. Forget the error code it threw but was able to bypass it till it was replaced. Check them for the little red/green lights and they sequence/flash.
  3. superteto
    superteto Previous User
    Feb 2014
    47
    no
    reach me :ercupa@netscape.net provide your email.
    superteto
  4. muske99
    muske99 Member
    Apr 2014
    5
    Illinois USA
    figured it out
    Thanks for the reply guys - I figured it out - the reason why 108 has no reference in the Hamada manuel is because the 108 code is for the sensor on the after market AirTech spray powder/infra-red dryer
    Turns out the mirror that the sensor light bounces off was caked with melted powder
    I have been running this press since 1997 - This may have happened 10 years ago but long forgotten - and maybe why it finally came to me
    Thanks again
    Dave
  5. BALAS
    BALAS Member
    Mar 2014
    26
    ABIDJAN
    If you did not get solution to the machine, I can remove you your cards and automate your machine. Simple solution and sustainable
    +225 09016639
  6. 1robe2
    1robe2 Previous User
    Apr 2014
    20
    managua
  7. just4sola
    just4sola Member
    Aug 2013
    11
    NG
    @superteto and @1robe2 I bet you want to sell your fake manuals to another victim!
  8. just4sola
    just4sola Member
    Aug 2013
    11
    NG
    Hamada H234A error 22 (1P lower cover) not going away
    @FFR428 I have Hamada H234A and am having error 22 (1P lower cover) for a couple of days now. i closed all the covers still error 22 is not going away. Please how can i bypass this error code. very urgent! Thank you for your time
  9. FFR428
    Feb 2008
    438
    CT
    It can be hard to diagnose things without seeing but I'll give it a try. I can't remember which cover 22 is, I'm not at work today. If the cover is loose this will trip the error message. I've had to add washers to the screws so covers don't move even the slightest bit as this can trip them. So take a good look at things. You can bypass the cover but it'll remain a safety issue until it's resolved. Look at the cover solenoid in question. You'll see 2 contact posts together and a 3rd one higher but the 3rd isn't a concern. The 2 that are side by side, pull the lead off and put it on the contact post right next to it. This will bypass the solenoid and allow you to run with the cover as is, open or removed. This is the same for all cover safety solenoids on the press. This should get you running for now until you can fix it.
  10. just4sola
    just4sola Member
    Aug 2013
    11
    NG
    Thank you for the quick answeer. i will give your suggestion a try ASAP will let you have feedback.
  11. just4sola
    just4sola Member
    Aug 2013
    11
    NG
    Hello FFR428, 22 error is lower cover error. I check the press looking for the cover solenoid but am not sure where I should look , you said 'Look at the cover solenoid in question. You'll see 2 contact posts together and a 3rd one higher but the 3rd isn't a concern. The 2 that are side by side, pull the lead off and put it on the contact post right next to it'
    Please where? Inside the door switch? Or in the electrical panel box?
  12. just4sola
    just4sola Member
    Aug 2013
    11
    NG
    Please see image for lower cover
  13. just4sola
    just4sola Member
    Aug 2013
    11
    NG
  14. just4sola
    just4sola Member
    Aug 2013
    11
    NG
    I have looked but don't know where the cover solenoid is, please where do I look? Thank you
  15. FFR428
    Feb 2008
    438
    CT
    Sorry took some time to snap a pic. Work has been busy. Your press looks a little newer than mine. But here's what mine looks like. When I need to work on machine with cover open or off I just switch the top connector to the next pin beside it. this will bypass the safety on that cover.
  16. just4sola
    just4sola Member
    Aug 2013
    11
    NG
    Thank you for the effort, yes mine does not have this (your pics) but it has Omron Door switch/Limit switch(attached)
    I solved the problem by changing fuse 2 inside the control panel. I was surprise myself because the manual
    says 22 is unit1 lower cover! in searching for help i read somewhere that when the fuse f2 goes out that the press
    may show anything, so i changed the fuse and all works perfectly. Thanks again we back on production.
  17. Ramon Barbosa
    Ramon Barbosa New Member
    Mar 2017
    Brazil contagem minas gerais
    Hi, I'm with this error 22, I already noticed everything that was said but nothing worked, the fuse already checked the electronic boards and I saw nothing, could help me to respect this error 22, because I do not have the electrical diagram of this machine if someone has thank you much!
    Good production to all, I await response, thank you
  18. Ramon Barbosa
    Mar 2017
    I actually need the H234A's electrical diagram.
