Error 50 quick master DI 46-4
2025
17
Iran
Hello, when I turn on the device, the CPC table starts to disconnect and reconnect, and after a few times, error 50 appears on the screen and a beeping sound comes from the device, and I can't fix it in any way. Please help me eliminate error 50, thank you.
Try to re- seat the X-7 plug ( circled in the picture) I believe it to be on the ZTK board or the one below it check for burn marks on the 2 plug wires on the far left, if they are scorched, they will need to be cleaned before re seating the plug. I have gone as far as hard wiring these wires direct to the board because of connection problems
  • Try to re- seat the X-7 plug ( circled in the picture) I believe it to be on the ZTK board or the one below it check for burn marks on the 2 plug wires on the far left, if they are scorched, they will need to be cleaned before re seating the plug. I have gone as far as hard wiring these wires direct to the board because of connection problems
    Thanks for your help, I will definitely let you know the results.
    Thanks for your help, I will definitely let you know the results.[/QUOTE
    I have two plugs in this part of the electrical panel that I don't know where they connect to.
